iptables: "target problem" or "invalid argume
executing some command like this (which should work according to man-pages) gives the error "target problem":
iptables -t nat -I OUTPUT 2 -p tcp --sport 1234 -j DNAT --to 127.0.0.1
or "invalid argument" when using "iptables -t nat -A OUTPUT...".
check if you have activated "CONFIG_IP_NF_NAT_LOCAL" in your kernel settings.
greuff
Absolute Beginner
Post by greuff »
You can also get these very descriptive "target problem" errors if you confuse POSTROUTING with PREROUTING in the nat table when you're trying to setup NAT rules (e.g. adding a rule to POSTROUTING when you want to do DNAT or adding a rule to PREROUTING for SNAT respectively)
