MySQL: Reset root password on Debian based distros
I've locked myself out of my MySQL, because I've forgotten my mysql-root password.
I didn't want to shutdown the MySQL server in order to follow general guides for resetting the password, like this one:
http://www.cyberciti.biz/tips/recover-m ... sword.html
On Debian systems, package scripts sometimes need to initialize database things - so the package system needs a mysql-user with administrator priviledges.
This user is called "debian-sys-maint" - and its password is randomly generated during installation time and can be found in /etc/mysql/debian.cnf
Now, you can use the debian-sys-maint account to log in:
mysql --user=debian-sys-maint --quick --password
(the "--quick" option is important, otherwise the new root password would be stored in your ~/.mysql_history)
Now within the mysql terminal, type the following to reset the password:
use mysql;
update user set password=PASSWORD("NEW-ROOT-PASSWORD") where User='root';
flush privileges;
quit;
That's it. You should now be able to login as mysql-root using your new password.
No service restart, no nothing. perfect!
MySQL generic password reset
I've now found a nice documentation at the mysql website, called "Resetting the Root Password: Generic Instructions", describing a plain-simple and effective way to reset the root password properly.
BUT: You have to stop/restart the mysqld for this - so keep that in mind on production systems, because you'll have a downtime.
Here's a step-by-step HowTo (so I remember it myself):
1) Shutdown the mysql daemon:
sudo /etc/init.d/mysql stop
(You might also try "sudo stop mysql" on upstart-based systems)
2) Restart the mysqld manually, and disable authorization completely:
Usually, "mysqld" is not running as root, but as user "mysql" - so to avoid ugly side effects of temporarily starting it with wrong (too high) permissions, use "sudo":
sudo -u mysql /usr/sbin/mysqld --verbose --skip-grant-tables
The "skip-grant-tables" option enables anyone to connect without password ;)
3) Log in to mysql (as any user):
mysql
4) Reset the root password:
mysql> UPDATE mysql.user SET Password=PASSWORD('MyNewPass') WHERE User='root';
mysql> FLUSH PRIVILEGES;
5) Shutdown the "open" mysql daemon and restart it properly:
Stop it:
mysqladmin -u root -p shutdown
NOTE: no sudo, no nothing, because mysql currently listens to anyone...
Restart it:
sudo /etc/init.d/mysql start
