By default, BASH's for loop uses the whitespace character as separator. This can be changed by setting the variable "IFS" to something else, as found on the web.
This is actually true, but there's a caveat!
Example:
function test
IFS="
FILES=`find . -name *.txt`
for file in $FILES; do
echo $file
done
Because the code is indented. Eliminate the spaces on the left side and it works:
function test
IFS="
echo $file
done
