vsftpd: "530 permission denied" with any username
vsftpd would refuse login with *any* username, giving the error message:
530: permission denied
The problem was, that the userlist option can either be used for denying access, or allowing access to all usernames listed in the "userlist_file" (usually "/etc/vsftpd_users").
In my case, the permission denied was caused by the following entry:
userlist_deny=NO
The default is "userlist_deny=YES", so uncommenting the above line solved my problem.
vsftpd: "550 permission denied" regardless of file permissio
I was able to login to vsftp, browse the folders, but could not create any file or folder, because I always got the errormessage:
550 Permission denied.
By default, the "write_enable" option is commented out in "/etc/vsftpd.conf". Enable it to look like this:
# Uncomment this to enable any form of FTP write command.
write_enable=YES
