Download website for offline use
I wanted to publish a php-based website made by me on a different server, but only as static HTML pages, since the php was only used for convenient automatic layouting of complex image arrangements (long story...)
Anyway:
I couldn't just use my browser and use "Save As...", because all the links would point to invalid filenames if saved as static HTML. They had to be rewritten. *sigh*
Thanks to the GNU/Linux community and the Free Software people, who always seem to have thought about almost everything - including implementing a comfortable solution, I found a short article on the Linuxjournal-website about creating an offline copy using "wget" - which immediately, and perfectly, came to the rescue and saved my day.
In order not to use that valuable information, I thought I'd post it here, too. The commandline arguments I've actually used, were like this:
$ wget \
     --recursive \
     --level=3 \
     --no-clobber \
     --page-requisites \
     --html-extension \
     --convert-links \
     --restrict-file-names=windows \
     --domains website.org \
     --no-parent \
WEBSITE_ADDRESS (like https://whatever.com/dude/...)
I like it when a tutorial also mentions which arguments, and why, they're using:
  • --recursive: download the entire Web site.
  • --no-parent: don't follow links outside the directory tutorials/html/.
  • --page-requisites: get all the elements that compose the page (images, CSS and so on).
  • --html-extension: save files with the .html extension.
  • --convert-links: convert links so that they work locally, off-line.
EDIT (2021-05-11): Added "--level" to avoid wget going crazy downloading the whole Internet. :shock:
wget: Self signed certificate
In case you're trying to download a HTTPS secured website that has a non-trustworthy certificate for one reason or another (self signed, expired, non-trusted CA, etc), you might want to add the following option to the above wget command:
--no-check-certificate
But be warned:
As wget already says:
To connect to http://www.somedomain.test insecurely, use `--no-check-certificate'.
Example error messages:
ERROR: no certificate subject alternative name matches requested host name
