Executing script: "permission denied" - even with 777
I've mounted an external USB drive on a Debian Squeeze installation.
All the folders have proper access rights, and I can read/write all files there. So far so good.
The confusing thing was, that when I tried to execute a bash script (or any other executable) that was stored on that volume, I got a:-bash:
./script.sh: Permission denied
Regardless of the access rights, I've set. I've even tried:
chmod 777 script.sh
No effect.
Copying the file to my home folder, and starting it from there worked.
Puzzling...
For some reason, the drive was mounted with the "noexec" option.
Call mount to see the actual options a drive is mounted with. In my case it looked like this:
/dev/sdb1 on /media/storage type ext3 (rw,noexec,nosuid,nodev,noatime,errors=remount-ro,user=pb)
Additional information:
I think I've figured out, why the "noexec" option was automatically added:
In /etc/fstab, I've had the option "user" enabled, so I didn't have to be root to mount it. After removing the "user" option, and mounting it as root, the "noexec" was gone. Very very strange...
However, if you want to mount a share as non-root, but execute files there, just add the "exec" option in /etc/fstab.
