When changing size and/or aspect ratio of the video panes (input / output) in VirtualDub, the image might show ugly aliasing artifacts like Jaggies, for example.
This is caused by the resizing algorithm used to display the image.
VirtualDub is able to use OpenGL's filters to resize the image with a better quality.
In order to enable a better resizing algorithm, do the following:
- Options > Preferences > Main > Display
- Chech the option "Use OpenGL"
- Save and exit the dialog
- Right-click on the video pane to resize
- Select a suitable resizing algorithm as "Preferred Filter" (Example: In v1.9.11, there are 3 available: Point, Bilinear and Bicubic)
