- Site Admin
Post
by ^rooker »
A clean way for removing a file suffix (.jpg, .txt, ...) using only bash-internal syntax is as follows:
FILE="bla.txt"
NAME="${FILE%.*}"
echo $NAME
This will output:
bla
- Chatterbox
Post
by peter_b »
Here's the opposite of ^Rooker's snippet:
How to extract the file suffix as string in Bash?
FILE="bla.txt"
NAME="${FILE##*.}"
echo $NAME
This will output:
txt
