I installed apache2, but later figured that I'd rather want to run "lighttpd" on my Raspberry Pi.
So, I thought I'd get rid of apache by simply executing:
apt-get --purge remove apache2WTF?
Since "apt-get" is not recursively removing packages (like aptitude could), one has to manually remove all apache2 packages:
$ sudo apt-get --purge remove apache2.2-bin apache2 apache2.2-common apache2-mpm-prefork apache2-utilsReading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be REMOVED:
apache2* apache2-mpm-prefork* apache2-utils* apache2.2-bin* apache2.2-common* libapache2-mod-php5*
0 upgraded, 0 newly installed, 6 to remove and 27 not upgraded.
After this operation, 11.8 MB disk space will be freed.
Do you want to continue [Y/n]? y
