The output of "lspci -vv": I know it's lengthy, and maybe boring for some, but I post this here for others to compare, in case they need it.
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
Subsystem: Super Micro Computer Inc Device 0624
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Bus: primary=00, secondary=01, subordinate=02, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: dfd00000-dfdfffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [88] Subsystem: Super Micro Computer Inc Device 0624
Capabilities: [80] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee0f00c Data: 4189
Capabilities: [a0] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #2, Speed 5GT/s, Width x8, ASPM L0s L1, Latency L0 <256ns, L1 <4us
ClockPM- Surprise- LLActRep- BwNot+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #1, PowerLimit 75.000W; Interlock- NoCompl+
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet- LinkState-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [140 v1] Root Complex Link
Desc: PortNumber=02 ComponentID=01 EltType=Config
Link0: Desc: TargetPort=00 TargetComponent=01 AssocRCRB- LinkType=MemMapped LinkValid+
Addr: 00000000fed19000
Kernel driver in use: pcieport
Kernel modules: shpchp
00:01.1 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: dfc00000-dfcfffff
Address: fee0f00c Data: 4191
LnkCap: Port #3, Speed 5GT/s, Width x8, ASPM L0s L1, Latency L0 <256ns, L1 <4us
Slot #2, PowerLimit 75.000W; Interlock- NoCompl+
Status: InProgress-
Desc: PortNumber=03 ComponentID=01 EltType=Config
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 0: Memory at dfe04000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
AFCap: TP+ FLR+
AFCtrl: FLR-
AFStatus: TP-
Kernel driver in use: ehci_hcd
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Bus: primary=00, secondary=05, subordinate=06, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: dfb00000-dfbfffff
Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #1, Speed 5GT/s, Width x4, ASPM L0s L1, Latency L0 <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
Slot #0, PowerLimit 25.000W; Interlock- NoCompl+
DevCap2: Completion Timeout: Range BC, TimeoutDis+, LTR-, OBFF Not Supported ARIFwd-
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Address: 00000000 Data: 0000
Capabilities: [90] Subsystem: Super Micro Computer Inc Device 0624
Capabilities: [a0] Power Management version 2
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
I/O behind bridge: 0000b000-0000bfff
Memory behind bridge: dfa00000-dfafffff
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #5, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <4us
Slot #4, PowerLimit 10.000W; Interlock- NoCompl+
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
I/O behind bridge: 0000a000-0000afff
Memory behind bridge: df900000-df9fffff
LnkCap: Port #7, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <4us
Slot #6, PowerLimit 10.000W; Interlock- NoCompl+
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 0: Memory at dfe03000 (32-bit, non-prefetchable) [size=1K]
AFCap: TP+ FLR+
AFCtrl: FLR-
AFStatus: TP-
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) (prog-if 01 [Subtractive decode])
Latency: 0
Bus: primary=00, secondary=09, subordinate=09, sec-latency=64
Memory behind bridge: df000000-df8fffff
Prefetchable memory behind bridge: 00000000de000000-00000000deffffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B-
Capabilities: [50] Subsystem: Super Micro Computer Inc Device 0624
00:1f.0 ISA bridge: Intel Corporation C202 Chipset Family LPC Controller (rev 05)
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Kernel modules: iTCO_wdt
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin B routed to IRQ 30
Region 0: I/O ports at f050 [size=8]
Region 1: I/O ports at f040 [size=4]
Region 2: I/O ports at f030 [size=8]
Region 3: I/O ports at f020 [size=4]
Region 4: I/O ports at f000 [size=32]
Region 5: Memory at dfe02000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee0500c Data: 41a1
Capabilities: [70] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
Capabilities: [a8] SATA HBA v1.0 BAR4 Offset=00000004
Capabilities: [b0] PCI Advanced Features
AFCap: TP+ FLR+
AFCtrl: FLR-
AFStatus: TP-
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin C routed to IRQ 18
Region 0: Memory at dfe01000 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at 0580 [size=32]
Kernel modules: i2c-i801
01:00.0 PCI bridge: Pericom Semiconductor Device e111 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=01, secondary=02, subordinate=02, sec-latency=64
Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Capabilities: [80] PCI-X bridge device
Secondary Status: 64bit- 133MHz- SCD- USC- SCO- SRD- Freq=conv
Status: Dev=01:00.0 64bit- 133MHz- SCD+ USC- SCO+ SRD-
Upstream: Capacity=16 CommitmentLimit=16
Downstream: Capacity=16 CommitmentLimit=16
Capabilities: [90] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [a8] Subsystem: Gammagraphx, Inc. (or missing ID) Device 0000
Capabilities: [b0] Express (v1) PCI/PCI-X Bridge, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- BrConfRtry-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr+ FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <1us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; Disabled- Retrain- CommClk+
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
Capabilities: [f0] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [150 v1] Virtual Channel
Status: InProgress-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
02:04.0 RAID bus controller: Silicon Image, Inc. SiI 3124 PCI-X Serial ATA Controller (rev 02)
Subsystem: Silicon Image, Inc. Device 7124
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
Latency: 64, Cache Line Size: 64 bytes
Region 0: Memory at dfd88000 (64-bit, non-prefetchable) [size=128]
Region 2: Memory at dfd80000 (64-bit, non-prefetchable) [size=32K]
Region 4: I/O ports at e000 [size=16]
Expansion ROM at dfd00000 [disabled] [size=512K]
Capabilities: [64] Power Management version 2
Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [40] PCI-X non-bridge device
Command: DPERE- ERO+ RBC=512 OST=12
Status: Dev=ff:1f.0 64bit+ 133MHz+ SCD- USC- DC=simple DMMRBC=2048 DMOST=12 DMCRS=128 RSCEM- 266MHz- 533MHz-
Capabilities: [54] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: sata_sil24
Kernel modules: sata_sil24
03:00.0 PCI bridge: Pericom Semiconductor Device e111 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=03, secondary=04, subordinate=04, sec-latency=64
Status: Dev=03:00.0 64bit- 133MHz- SCD+ USC- SCO+ SRD-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
Status: InProgress-
04:04.0 RAID bus controller: Silicon Image, Inc. SiI 3124 PCI-X Serial ATA Controller (rev 02)
Interrupt: pin A routed to IRQ 17
Region 0: Memory at dfc88000 (64-bit, non-prefetchable) [size=128]
Region 2: Memory at dfc80000 (64-bit, non-prefetchable) [size=32K]
Region 4: I/O ports at d000 [size=16]
Expansion ROM at dfc00000 [disabled] [size=512K]
05:00.0 PCI bridge: Pericom Semiconductor Device e111 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=05, secondary=06, subordinate=06, sec-latency=64
Status: Dev=05:00.0 64bit- 133MHz- SCD+ USC- SCO+ SRD-
Status: InProgress-
06:04.0 RAID bus controller: Silicon Image, Inc. SiI 3124 PCI-X Serial ATA Controller (rev 02)
Region 0: Memory at dfb88000 (64-bit, non-prefetchable) [size=128]
Region 2: Memory at dfb80000 (64-bit, non-prefetchable) [size=32K]
Region 4: I/O ports at c000 [size=16]
Expansion ROM at dfb00000 [disabled] [size=512K]
07:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
Subsystem: Super Micro Computer Inc Device 0000
Region 0: Memory at dfa00000 (32-bit, non-prefetchable) [size=128K]
Region 2: I/O ports at b000 [size=32]
Region 3: Memory at dfa20000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [e0] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <128ns, L1 <64us
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [a0] MSI-X: Enable+ Count=5 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00002000
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
CESta: RxErr+ BadTLP+ BadDLLP+ Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 14, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number 00-25-90-ff-ff-a4-e3-7a
Kernel driver in use: e1000e
Kernel modules: e1000e
08:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
Interrupt: pin A routed to IRQ 18
Region 0: Memory at df900000 (32-bit, non-prefetchable) [size=128K]
Region 2: I/O ports at a000 [size=32]
Region 3: Memory at df920000 (32-bit, non-prefetchable) [size=16K]
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number 00-25-90-ff-ff-a4-e3-7b
09:03.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200eW WPCM450 (rev 0a) (prog-if 00 [VGA controller])
Latency: 64 (4000ns min, 8000ns max), Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 11
Region 0: Memory at de000000 (32-bit, prefetchable) [size=16M]
Region 1: Memory at df800000 (32-bit, non-prefetchable) [size=16K]
Region 2: Memory at df000000 (32-bit, non-prefetchable) [size=8M]
Expansion ROM at <unassigned> [disabled]
Capabilities: [dc] Power Management version 1
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
