GNU make error: "multiple target patterns"
I tried to add targets to a makefile for ffmpeg's FATE test suite, when I ran into the problem that "make fate" refused my changes with the following error message:
In my code I had copy/pasted some lines that create Makefile targets, which ended with a trailing backslash because they were multiline statements.
The following code block was the culprit:
FATE_FFV1_LEVEL1 := $(FATE_FFV1_LEVEL1:%=fate-ffv1-enc-%) \
                    $(FATE_FFV1_LEVEL1:%=fate-ffv1-dec-%) \
FATE_FFV1_LEVEL3 := $(FATE_FFV1_LEVEL3:%=fate-ffv1-enc-%) \
                    $(FATE_FFV1_LEVEL3:%=fate-ffv1-dec-%) \
To fix this problem, either add a blank line between these 2 variable assignments:
...or remove the trailing backslash at the end of each statement's last line.
