At least not in the default repositories.
So I'm using "parted", but most of the documentation found refers to its interactive mode. I'm dealing with 45 drives per chassis, so I need to script it.
Thanks to a blog post by Roderick Tapang, I now know that one can use "--script -- <command>".
Here's how you script "parted" for creating RAID partitions on 3 TB WDC Red disks:
#!/bin/bash
RAID_DEV="$1"
RAID_NAME="$2"
DISKS="$3"
echo "Creating SoftRAID using the following devices:"
ls -la $DISKS
if [ -b "$RAID_DEV" ]; then
echo "ERROR: '$RAID_DEV' already exists."
exit 2
fi
for DISK in $DISKS; do
echo "Disk: $DISK"
if [ ! -b "$DISK" ]; then
echo "ERROR: '$DISK' is not a block device."
exit 1
fi
# Create GPT partition table:
parted $DISK --script -- mklabel gpt
# Set units to Sectors (s):
parted $DISK --script -- unit s
# Create one primary partition with 100% size, starting at sector 2048:
parted $DISK --script -- mkpart primary 2048s 100%
# Set the partition type to RAID:
parted $DISK --script -- set 1 raid on
done
# Wait a bit for kernel partition tables to update:
sleep 10
# Create the RAID:
echo "Creating RAID '$RAID_DEV' with name '$RAID_NAME'..."
CMD="mdadm --create $RAID_DEV --level 5 --raid-devices 4 --spare-devices 1 -N $RAID_NAME $DISKS-part1"
echo "$CMD"
eval "$CMD"
