Linux KVM: Delete virtual machine client
HowTo remove a VM-client from a libvirt KVM host, using "virsh"
1) Start the "virsh" shell:
As root (or using "sudo"), run the following command on the KVM host:
$ virsh
2) Shutdown the client:
You can get a list of all clients on that KVM host:
list --all
It'll return something like this:
 Id    Name                           State
 2     my-kvmclient                   running
Use the "Name" to address the VM-client and shut it down:
shutdown my-kvmclient
If successful, "list --all" will show the machine as "shut off":
 Id    Name                           State
 -     my-kvmclient                   shut off
3) Undefine the client's domain:
undefine my-kvmclient
That's it. :D
