Bash: "read" input while inside a while/read loop
Usually, in bash the command "read" is used for "press any key to continue" scenarios:
read -p "press any key..."
This conflicts however, when calling it inside a while loop that uses "read" to e.g. iterate through a file:
while read LINE; do
   read -p "press any key"
done < $FILE
The "read" used to wait for a key, literally "eats up" every 2nd line of the input file, because the stdin is now colliding between 2 different inputs.
Use a for loop with "cat" instead of while/read:
for LINE in $(cat $FILE); do
done
:D
NOTE: Versions that use a different pipe than stdin can be found in the site, linked below.
