VMWare: connect vSphere client to ESX over SSH tunnels
This describes how you can connect to an ESX VMWare host remotely, using SSH-tunnels:
1) Required ports:
Add these ports as local forwards (in e.g. PuTTY):
  • 443 (https)
  • 902
  • 903
If the SSH-tunnels are configured and work properly, you should now be able to open the ESX web-interface in your browser, under the following URL:
https://localhost
If you don't have a vSphere Client already installed, you should see download links for it (or other clients, such as Linux commandline, etc) on that web page.
2) Add a local hostname entry:
If the web-interface of the ESX host loads correctly, you do have established the connection.
It is however necessary to add a local hostname to use - because for name-resolution reasons, "localhost" can not be used for this.
Edit WINDOWS\system32\drivers\etc\hosts and add an entry for "127.0.0.1".
The name you assign doesn't matter.
For example:
127.0.0.1    target-esx
3) Connect using vSphere client:
Now, enter the hostname you've put into the drivers\etc\hosts file as hostname to connect to.
Of course, also proper credentials ;)
That's it! :D
Thanks go to the great and simple HowTo "VMWare vSphere Remote Access via SSH Tunnel" (by Anthony Eden).
I just always like to have a copy of the information here, in case the source should disappear for some reason.
