Validate XMLs against XSDs
This HowTo describes how to validate XML files, using XML Schema Definition (XSD) files, using "xmllint".
Here's the basic commandline:
$ xmllint --noout --schema $XSD_FILE $XML_FILE
To make things more interesting, I'll use a somewhat real-world example of a METS Metadata XML export - cmmon in long-term preservation context.
Let's say we have the following set of files: Validating if the XML file (metadata_mets.xml), generated by a preservation system is actually a valid METS file, we use the proper schema definition (mets.xsd) and validate it using xmllint:
$ xmllint --noout --schema mets.xsd metadata_mets.xml
If everything is fine, the result should be:
metadata_mets.xml validates
If not, you will receive information about what/where in the XML file does not validate against the given XSD.
