Today I did set up a minimal samba config for quick file transfer as I've done dozens of times already. To my surprise, when trying to connect from a windows box to the showing share, I got an access denied error. The log files on the samba server showed a long stack trace, so apparently something hit the wall:
[2017/12/16 20:20:30.464869, 0] ../source3/lib/popt_common.c:68(popt_s3_talloc_log_fn)
Bad talloc magic value - access after free
[2017/12/16 20:20:30.465215, 0] ../source3/lib/util.c:789(smb_panic_s3)
PANIC (pid 7513): Bad talloc magic value - access after free
I followed the white rabbit until it looked like a library was the culprit and a new google search with those additional infos pointed me to this thread, where shane-hill suggested to reinstall shared libs that might be the issue:
$ sudo apt-get install --reinstall libsmbclient libsmbclient-dev libtevent0 libtalloc2
$ sudo service smbd restart
$ sudo service nmbd restart
