Installed mysql-server (actually "MariaDB" now in Debian Stretch
I was never asked for a mysql root password...
Seems that the following command must be called:
$ sudo mysql_secure_installation
Assuming I could login now, I got:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
For "classic" authentication behavior, you must switch the (new) default 'unix_socket' to 'mysql_native_password'.
See details (and more detailed solution at stackoverflow and step-by-step instructions at Childsplay's blog).
Here's the short version:
$ sudo mariadb -u root
USE mysql;
UPDATE user SET plugin='mysql_native_password' WHERE User='root';
FLUSH PRIVILEGES;
EXIT
