Workaround: ddrescue & "input file disappeared"
Thanks to Ketil Froyn's feature suggestion for ddrescue, here's a workaround for ddrescue exiting when problematic source device "disappears" :(
If ddrescue exits with the following error message, although the input device can be read again a few seconds later...
ddrescue: input file disappeared: No such file or directory
...use this command to "rudely" restart ddrescue forever, when it exits:
$ while true; do ddrescue /dev/sdb sdb.dd sdb.log; sleep 10; done
You have to kill the loop manually, once ddrescue has finished:
Ctrl + C
