WRT54GL + Tomato = SSL ERROR / No https access
After flashing my good old WRT54GL (v1.1) from original Linksys firmware (v4) to Tomato (1.28), I couldn't access the webinterface over https! :shock:
By default, Tomato's webinterface over HTTP is disabled... :?
Firefox (v71.0) refuses to connect, showing the following error message:
Secure Connection Failed
An error occurred during a connection to 192.168.1.1. SSL peer rejected a handshake message for unacceptable content.
Error code: SSL_ERROR_ILLEGAL_PARAMETER_ALERT
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem.
Unfortunately, you don't get infos or details about Tomato's certificate that seems to be "outdated" in a serious way.
Chromium is even more silent and just says: "ERR_SSL_PROTOCOL_ERROR"
[WORKAROUND]
I haven't been able to re-generate a new certificate that firefox is happy with (or maybe it's Tomato's https-server?!).
BUT: You can enable the HTTP webinterface over Telnet 8)
1) Login as root per telnet:
$ telnet 192.168.1.1
Trying 192.168.1.1...
Connected to 192.168.1.1.
Escape character is '^]'.
PBS1 login: root
2) Enable HTTP:
$ nvram set http_enable=1
$ nvram commit
This changes the setting and stores it back in the non-volatile memory (nvram).
Afterwards reboot to apply the changes:
$ reboot
Now you should be able to access Tomato's webinterface over "http://" and deal with the SSL problem later.
Firefox 33.0 won't open a specific local application: Error code: sec_error_invalid_key
