PHP7 Notice: "A non well formed numeric value encountered"
I'm checking how much memory PHP has free to use, before further execution:
ini_get('memory limit')
usually returns a number with a size modifier character, like: "128M"
Before PHP7 (7.3?), php would just use that string as-is, ignore the non-numeric part, when used in a calculation.
This seems to have changed and now I get the following warning:
PHP Notice: A non well formed numeric value encountered in /opt/dva-profession/devel/trunk/bin/include/ArchiveStructure.php on line 2372
There's an example for converting a php.ini value like this to a number in PHP docs for "ini_get()", but It seems to suffer from the same new PHP7 stricter-ness :D
So I've changed the first lines to this:
  $val = trim(strtolower($val));
  $last = $val[strlen($val)-1];
  $val = rtrim($val, "gmk");
I lowercase the ini value first, then extract the last character - and then remove any of the letters G, M or K (in lowercase) and store the number-only in "$val".
Now it works without warnings:
     * Converts a PHP config value data size with a modifier character to a
     * numeric byte value.
     * Code is an exact copy from:
     * https://www.php.net/manual/en/function.ini-get.php
    public static function return_bytes($val) {
        switch($last) {
            // The 'G' modifier is available since PHP 5.1.0
        case 'g':
            $val *= 1024;
        case 'm':
            $val *= 1024;
        case 'k':
            $val *= 1024;
        return $val;
