md5deep examples
md5deep examples
Two basic commands for "a default" usage of "md5deep":
1) Create a recursive hashcode manifest:
$ md5deep -r -e -l . > ~/cam202206.md5deep
  • -r: Recursive. Also go into subfolders.
  • -e: Show "how long it may take" for each file.
  • -l: Output relative file paths (in the manifest).
  • .: Current folder = "."
  • > ~/cam202206.md5deep: Output the calculated hashes (=manifest) into the given filename.
The manifest name is completely arbitrary. I recommend using ".md5deep" as suffix. It's clear(er) then that it's a hashcode manifest. Yet also indicates that it ain't compatible with the good old "md5sum" (and friends) tools, since it has a different layout/information format.
2) Validating files against that generated manifest:
$ md5deep -m $MANIFEST -r $FILES
Explanation:
  • -m: Enables matching mode. Each matching (=hashcode identical = OK! :D) file's name will be printed.
  • $MANIFEST: put your previously created md5deep-hashcode-manifest filename here.
  • $FILES: Filename or file-mask of files to validate.
Example for digital video camera recordings (Panasonic), which creates files/folders like "DCIM/112XDPHH/S110002.MP4":
$ md5deep -m ~/xxx/cam202206.md5deep -r 112XDPHH/*
It seems that md5deep is able to "find" files in the manifest, as long as their folder/filename is found in the manifest. I haven't tried with duplicate filenames in separate folders though.
Have fun!
md5deep: Integrity check
If you'd like to verify if all files in an md5deep-manifest-file are present and okay, use the "audit" mode:
$ md5deep -a MANIFEST.md5deep
If all files are okay, it will output nothing (<silence>). It should only list/show the entries that are erroneous.
