Here's a rough example for a non-blocking IP (TCP) port listening for incoming connections, without blocking the video playback:
(OS is Xubuntu 20.04, MPV v0.32.0)
-- Import LuaSocket library
local socket = require("socket")
print("Socket.")
-- Create a TCP socket and bind it to the localhost, on port 12345
local server = assert(socket.bind("127.0.0.1", 12345))
server:settimeout(2);
print("Server.")
function wait_socket()
print("listening...!")
-- Start listening for connections
local client = server:accept()
if client == nil then
print("nix")
else
-- Handle the client connection
client:send("Hello from MPV!\n")
client:close()
end
end
mp.add_periodic_timer(1, wait_socket)
Known issues:
- Timer continues when trying to quit/exit MPV. Must be killed by Ctrl+C.
Based on the above example snippet, here's a LUA script for MPV that opens a port and listens for "key=value" commands.
In this example, it takes a "seek=frames" argument to jump to a position in the clip, using the "container-fps" to deduce the position in seconds:
local server = assert(socket.bind("*", 12345))
server:settimeout(0.5);
local client
-- print("listening")
local msg
-- print("nix")
else
msg = client:receive('*l')
client:close()
end
handle_msg(msg)
end
function handle_msg(msg)
if msg == nil then
-- empty message, nothing to do.
return
end
print("handling: " .. msg)
-- Iterate through key=value commands, and convert them
-- to a table in one go:
t = {}
for k, v in string.gmatch(msg, "(%w+)=(%w+)") do
t[k] = v
print("key: " .. k .. " / value: " .. v)
if k == 'seek' then
local fps = mp.get_property_native("container-fps")
local pos = t['seek'] / fps;
print("seek: " .. pos)
mp.commandv("seek", pos, "absolute", "exact")
end
end
end
function cleanup(event)
print("Goodbye!")
-- Shutdown sockets:
if client ~= nil then
client:close()
end
if server ~= nil then
server:close()
end
end
mp.add_periodic_timer(0.5, wait_socket)
mp.register_event("shutdown", cleanup)
