Here's a small script I wrote for a centralized backup environment.
Example: 4 workstations and 1 server. Each workstation has rsync running as demon, and the server backs up the folder from the clients using rsync.
In order to make this easier and maintenance free, I wrote a small script that queries rsync for a list of folders it is responsible for and synchronizes each "published" entry.
#!/bin/bash
# @author: ^Rooker
# @date: 13.Aug.2007
# @description: Gets a list of published rsync entries from a client, retrieves all of them and finally compresses each one - or makes a hardlink copy (my favorite).
RSYNC="/usr/bin/rsync"
RSYNC_PORT=873
RSYNC_HOST="to-be-backed-up.mydomain.com"
RSYNC_GET_LIST="$RSYNC --port $RSYNC_PORT $RSYNC_HOST::"
DEST_DIR="/here/is/my/backup/folder"
OLD_DIR=`pwd`
TIMESTAMP=`date +%Y%m%d_%H%M`
function get_backup_list
# use 'sed' to strip the comment of each rsync entry:
BACKUP_LIST=`$RSYNC_GET_LIST | sed -e 's/\s".*"/ /g'`
function pack_service
FILENAME="$TIMESTAMP/$1.tar.bz2";
echo "Packing $1 as \"$FILENAME\"..."
mkdir -p $TIMESTAMP
tar -cjf $FILENAME ./$1
function make_snapshot
SNAPDIR=$TIMESTAMP
mkdir -p $SNAPDIR
cp -al ./$1 $SNAPDIR/
function retrieve_services
for service in $1; do
echo "Fetching '$service'... ";
$RSYNC -azt --progress --numeric-ids --delete --timeout=600 --port $RSYNC_PORT $RSYNC_HOST::$service ./$service
#pack_service $service
make_snapshot $service
done
cd $DEST_DIR
get_backup_list
retrieve_services "$BACKUP_LIST"
cd $OLD_DIR
The uncompressed folders in the root of $DEST_DIR are left on purpose to make it easier for rsync to find changes and only transmit deltas.
(Edit on Oct.29th, 2007: Added ability to use hardlink snapshots)
Unicode?
I've had problems with special characters (e.g. german umlauts) transferred from Windows to Linux. My bash displayed them as question marks (?) and when browsing the files through Samba, they turned to underscores (_). *sigh*
Files were copied fine, but files removed from folder1 should be deleted in the target folder, which just didn't happen - except for files in subdirectories.
