The pxelinux.cfg/default configuration block shown in the forum entry on UBCD about PXE booting didn't work for me.
At all.
Here's roughly what I did:
1) I already had a PXE server up and running.
If you don't, then checkout some HowTos on doing that.
2) Download a syslinux tarball:
You'll find syslinux downloads on the kernel.org servers
I've just used "v4.07" (but you might also try the latest one).
3) Copy certain files from syslinux tarball over to your pxe folders:
tar -xjvf syslinux-4.07.tar.bz2
cp syslinux-4.07/core/pxelinux.0 /var/tftp/
mkdir -p /var/tftp/com32/modules
mkdir -p /var/tftp/com32/menu
cp syslinux-4.07/com32/modules/*.c32 /var/tftp/com32/modules/
cp syslinux-4.07/com32/menu/*.c32 /var/tftp/com32/menu/
ln -s /var/tftp/com32/menu/menu.c32 /var/tftp
ln -s /var/tftp/com32/modules/config.c32 /var/tftp
...5) Mount the UBCD iso-image:cmd.c32, config.c32, linux.c32, menu.c32, vesamenu.c32
I've mounted the UBCD's ISO image in /var/tftp/iso-mounted/UltimateBootCD-ubcd527:
sudo mount -o loop ubcd527.iso iso-mounted/UltimateBootCD-ubcd527Code: Select all
LABEL ultimate_boot_cd-527
MENU LABEL Ultimate Boot CD (v5.2.7)
KERNEL menu.c32
APPEND iso-mounted/UltimateBootCD-ubcd527/ubcd/menus/syslinux/main.cfgCode: Select all
ln -s iso-mounted/UltimateBootCD-ubcd527/ubcd/ /var/tftp/ubcd
