Services on computer behind firewall are not reachable from outside, although iptables are properly routing ports through.
Also, this computer is perfectly available from the firewall and other "internal" IPs.
Check if the unavailable computer has the correct gateway set.
In my case, I had a wrong route option set for THIS machine only, so all answers to requests routed through from outside could not find their way back to "the world".
